Hi, I need to use some HMTL stacks and while editing the code, the “smart quotes” option always comes back. The bad thing is that the code is totally screwed up by this. It looks ok in the HTML stack, but not in the code.
How can I disable “Smart Quotes” once and for all. This is driving me nuts…
Agree… Smart Quotes are invented by the devil. Gets me every now and then too.
Really think they should be turned off by default – instead of the other way around.
Hey @robert_muench - Ignore Formatting will ignore any formatting (differences). You can also highlight the code and go to Format > Clear Formatting. This is something that would be best done after any code changes, etc.
Smart quotes should be turned off by default in the latest versions of RapidWeaver. We’ll look into this and see if there’s anything else we can do to prevent it - though, the system may take over!
Yes, the thing was, it always came back. The clear formatting is not a property for future entries but only for the existing text. So, starting to add things, got formatting stuff back again.
@nikf Had this happen to me last night, could not figure out for the life of me why copying and pasting code from one project to another did not work. Ended up copying the entire stack it was in and that worked, but I am running 6.2.3 and I was still getting the smart quote issue, so the OS must override that.
Problem with turning it off in the OS… if you – as I believe many of us do – work with both webdesign & layout for print… lots of text for booklets > it’s a turn on/off hell.
For coders the smart quote feature is annoying.
For RapidWeavers not dealing with code - but maybe writing a log of blog posts, the smart quote feature is probably a good thing.
So… for this feature to be really smart it would have to be up to each user to decide what suits their purpose best. At setting for either RapidWeaver or maybe the project… cause I have both projects where I never touch a single line of code – and projects where I do.
I emailed RealMac about this back in May and they responded saying they didn’t see any issues. I have problems with this all the time. Looks fine in RW, then when published doesn’t work, have to go back and reset the smart quotes.
Just make the default OFF, PLEASE!!!
I also ran into this problem today. I’m really expecting an HTML stack to not transform quotes to smart quotes. I finally figured out what was happening, but not right away! Could this bug be fixed?
As noted above, the default is set to Off. The system overrides this, and we cannot work around it. You’ll need to turn off the Smart Quotes feature in System Preferences.
