HTML Not Working
I am trying to insert code provided by another site to show that my site is verified by that site. I pasted their code into a Paragraph Pro stack that already has text in it on the About page. It does not show up though when published. I pasted the code below but it isn’t showing up.
The code is as follows:
To show code on this forum you need to mark it as preformatted text.
 ```Why did you not use an html stack?
The usual problem with pasted code is curly quotes caused by not pasting using Cmd-Shift-V and not using ‘ignore formatting’.
Some apps change quotes to curly quotes by defalut – so if the code is pasted to a note app or similar before pasning it to RapidWeaver & a Stack – the code won’t work.
Luckily RapidWeaver has a ‘remove smart quotes’ feature.
This could be the problem – but could also be so much more …
Best, DeFligra
Mac’o’holic | Stack’oholic | Web’o’holic
