Is there a fast and easy way to have the paragraph indented? Instead of leave a white space between the lines. Just thinking as an old-timer printer. Via a stack will be a breeze. Thanks in advance.
In a conventional Text Stack you could simply increase the left side Padding and/or Margin.
For first line only, one of the list Stacks might do that.
Gracias Mark
I will check the ones I Have.
You could just use the code for an em space, $emsp; at the beginning of the paragraph.
Not a particularly elegant solution, I know. Also, I’m not sure how you would prevent the extra space between paragraphs.
Printery,
I found this, which looks so good I might get it myself
