Hi
I use RapidBlog on quite a few sites and am slowly updating them all. But the RW6 update I’ve downloaded from Loghound (here) is just not working. When I try to install it I get this message:
Anyone else having any problems at all? And if so, have you managed to sort it?
Thanks!!
Yeah, I’ve got a support query in with Loghound about RapidBlog, though it’s about a slightly different problem.
I managed to install RapidBlog for RW6 without any problems; it immediately asked to upgrade to a newer version but this worked fine.
My problem is that RapidBlog for RW5 listed on that page doesn’t work at all.
Have you approached Loghound direct?
Hi
Not yet, thought I’d see if anyone was experiencing similar issues, first, but getting on to Loghound now!
A fairly easy sort out from Loghound:
Go to the ‘manage addons’ area in RapidWeaver and right click on a plugin and say ‘reveal in finder’ – then copy the plugin over to this folder and restart RW and you that should fix it.
and if its like its not even in rw 6 mine say only rw5 i can install this ? i cannot even put number or any in it
