In trying to sort out my problems with Rapidblog I got the following response from YourHead:
We have looked into the issues that we are having, and we seem to get similar errors.
As you know. we took this project over from LogHound. We have been working on updating all of the LogHound plugins. Unfortunately, we have not been able to resolve the issues with RapidBlog. We have looked into the problems, but there is definitely a concern that with this particular plugin the issues are just too fundamental to fix. We will certainly do the best we can, but we just canât say for certain that these issues will be resolved. Unfortunately, if you are looking for a resolution in the near term, it might be more worthwhile to look for an alternative solution. I am sure there are users on the forum that can recommend alternative ways. I just donât want to keep you hanging on when I canât say for sure whether weâll be able to resolve the issues.
So, can anyone suggest an alternative remote blog platform that works with RW? I have several clients using Rapidblog so I would need to extricate them too. Also to say I do use RSS feeding through from the ârealâ blog to the homepage (âLatest newsâ) so need that function too.
