Hey all,
back in 2013 I purchased Lifestream from Weaveraddons, however, the stack doesn’t seem to work anymore.
Any idea what happened? Maybe it’s not compatible with Stacks 3.0 ?
Stevie
Hey all,
Stevie
The demo on the Weaveraddons site doesn’t work either, and he hasn’t Tweeted since 2013.
No that that means he’s disappeared, but I’d look at an alternative if I were you.
The Wall stack from @yuzool seems a good replacement.
Ah, good point! I was wondering already. Well, I just noticed that I already purchased the Wall stack, when I subscribed to @yuzool
Will check it out, thanks Neil!
Okay, that seems to work pretty well, however, I’m trying to limit the number of posts to a minimum, e.g. Twitter 3 posts, RSS feed 3 posts. But the “white space” used isn’t limited by the number of posts I’m chosing. Is there a way to make the Wall responsive?
The Wall demo is responsive.
What theme are you using? Do you have a link?
Hey Neil,
I’m using Regen from Multithemes. Actually there isn’t shown anything, but a lot of space.
I put the stack in the extracontent3 (footer, the grey area). In Rapidweaver, the preview shows
the Tweets. So, now there are 2 problems at once
No Twitter and not responsive.
To be honest, I’m not sure. I don’t have Wall so I can’t test it.
I would start another thread about your issues, or contact @yuzool directly. I’m sure it’s something pretty simple to resolve.
Good idea, will do that! Thanks Neil
As you can see from the demo page @Stevie1 :
http://demo.yuzoolthemes.com/wall/
Wall is completely responsive
Hey Michael!
Thanks for the info!
Apparently the theme I use, has some troubles with the stack
Send in an email with more info if you want us to take a look at it
Hope the project is going well
Hey Michael!
Thanks! I will, I’m just slammed with work at the moment. I need to upload a test-version, so that I can show you the issue. Will get back to you ASAP. Hopefully tomorrow.
Stevie
