Good day all.
So I’m sure this could be accomplished with CSS, just not sure how.
Or maybe with a stack that’s out there?
I have some type that is centered (left-right) on a page. I want to add line about and below with some padding between the line and the type so that the type is centered between the lines.
If possible, the lines should be the width of the type plus maybe 10 pixels so the overhang the type a bit. But, not sure if that will work.
I’m guessing a box with a border top and bottom and add padding to make it look like the type is centered top-bottom ? But, how to get the box width to be wide enough so the type doesn’t split to two lines. Possible?
Thanks,
Paul
