Make text italics?
I have used the basic text stack to put a picture caption under an image which is within a Floaty stack. There does not appear to be a way to make it italic. I have the code for this, but how would I insert it into the source code? I can’t find a way to do that.
gary555,
Best not to insert anything directly into RW’s source :slight_smile: .
What happens when you select the text (in the usual way… drag-extend with your mouse; or triple-click) and you press Cmnd-I?
That worked! I guess I am the last person to learn that! Well, finally time I did, huh? Thank you very much!
gary,
We all come here to learn :slight_smile: !
Glad it worked. Good luck…
