Hello everyone !
I have a Google map here, in the sidebar, using Map2 from Doobox.
My problem is ; this maps appears normally when using Safari or Chrome, and do not appear when using Firefox.
Do you have any idea why ?
Hello everyone !
OK ; it seems to be a simple API key, Iâm working on itâŚ
Done ! Sorry guys !!!
same problem here.
it doesnât show in Firefox.
What did you do?
To show Google Maps on a website, you need an API key now.
This is what happened : I made my âAPI keyâ settings to quickly, with just âwithout www addressâ (hope Iâm clear). I mean ; I just put my website adresse, with no www, in the âauthorized address fieldââŚ
And so, when I was displaying my page in Safari and Chrome, I was on the âwebsite.comâ address.
When I was trying in firefox, I was on the âwww.website.comâ address, I didnât pay attention to thatâŚ
So ; I completed the API. Does this answer to your question ?
Hm ⌠not really, but I think I didnât get your point, sorry.
What I meant is: Opening your site https://www.vifimo.com/ in Firefox the map doesnât show up.
Opening it in Safari it shows up âŚ
So a totally different issue âŚ
Sorry âŚ
Itâs because I didnât pay attention that :
My API keys was configured only for the www address.
So it worked in Safari and Chrome each time because the âmemorized URLâ was the www one.
And it didnât in Firefox because the memorized URL was just âvifimo.comâ.
If I had typped the âvifimo.comâ address in Safari, it wouldnât have worked either.
The problem did not come from Firefox ; just from my API settings.
So now I completed the API key informations, and itâs ok everywhereâŚ
Hope I made myself understandable
You should redirect one or the other. Decide if you want your URLâs to be www
or not to have www
on them and setup redirects so no matter what the user enters it ends up at proper URLâs.
Otherwise search engines may consider the two URLâs (www and non-www) to be duplicated content.
Thanks, I did that.
