Problems with POINTS (JoeWorkman)
Hi everyone,
I am having a problem with POINTS. I use the lightbox link for 7 points on my map. But when I click on one point - then not ONE but SEVEN lightbox-windows open. When you close the lightbox, you have to close it seven times. Not so nice. Every link has a unique ID.
Does anyone else have these problems?
THANK SO MUCH!
Sounds like a conflict with another stack on the page. Are you using Foundation?
I have a similar problem trying to implement WWโ€™s Supermenu on a Foundation page. Supermenu also requires unique idโ€™s for each instance but somethings conflicting and itโ€™s causing the whole page to become selectable somewhat like yours.
It would be nice to seeing an obvious solution before I spend half a day trying to isolate the cause.
I have a feeling @rwoldie is using an old version of Lightbox, this sounds like an old bug that use to happen with Joeโ€™s Lightbox stack. Joe fixed this in a recent update of the stack.
Yeah. That was easy. Updated the Lightbox and it works like charme! Thanks Robert!!! :blush:
@ricinport No its not foundation. Sorry have no idea what is causing your problem.
Glad we got it working! I was also doing the support ticket you sent in. Will close that now.
