Missing plugins after upgrading iMac
After getting a new iMac and upgrading to 10.11, when I opened RW 5.3 there are only native plugins, no stacks etc. I tried to upgrade to v5.4 but it would not work. I purchased v6. Still no plugins. How do I get all of my plug ins back.
All the RapidWeaver addons are stored in the RapidWeaver folder inside your Library folder. For RapidWeaver v5.x thats:
your_home_directory/Library/Application Support/RapidWeaver
But since you’ve updated a few things it would probably be wise to just download fresh copies of these things right from the developers. That will ensure you get the latest version.
For Stacks (and any other YourHead or LogHound plugin) you can go to http://yourhead.com – all our plugins are downloadable from there. That will ensure that you get the versions that works well with RapidWeaver 6 and RapidWeaver 7.
If you need to lookup any of your serial numbers for registration, you can find a link on our site (it’s on the bottom righthand side of every page) or just click here: http://yourhead.com/serial
If you need any other help with Downloads or registration just contact our support folks.
Isaiah
Does it make a difference that I can see the plugins in RW5 but not is RW6&7. They are in my library but not being seen by RW 6-7?
How do I get 6-7 to see the items in the your_home_directory/Library/Application Support/RapidWeaver path?
Open RapidWeaver 6 or 7. Hold down the command and option keys and push the 7 key. This open the addons folder. All of your stuff should be in there
Can I just move all of the files in the library where I see them to this folder manually, i.e. drag and drop?
Probably, but I would copy them over, especially if you want to continue to use RW 6
I have migrated to RW7 now. Would this still apply?
