Hi and good day,
I’m setting the top margin, but the Banner stubbornly clings to the Foundry navbar ?
Any assistance would be greatly appreciated!
With best regards,
Omar KN
Hi and good day,
With best regards,
Omar KN
Hi there @OmarKN – It’s unfortunately a bit hard to tell anything based on just a screenshot. If you’d like to send me a ZIP file containing your project file I’d be happy to take a quick look at it for you.
Do you have ‘Pair with Banner’ selected in your Nav Bar settings (it is the last option at the bottom of the settings)?
YES = I had ‘Pair with Banner’ selected in the Nav Bar settings, thank you!
