Anyone know of any good Box Shadow Stacks? One that’s similar to Transbox but that are compatible with RW 8.
Try @joeworkman Jack…lots of options
Looks great but it’s a bit pricey and I just really needed a stack that does a box shadow effect.
You or Anyone Else have any other solutions?
Take a look at:
https://stacks4stacks.com/shady
What do you want to add the shadow effect too? Containers, images, etc.?
To a Stacks Column stack.
To the content in the columns or the actual columns themselves?
The actual columns.
I was going to suggest using css but that might cause issues if applied to regular columns… Not at my pooter right now, but pretty sure Big White Duck Blueprint stack has a drop shadow option, so stick the columns in a Blueprint stack.
Okay thanks for the help.
