Continuing the discussion from Parallax Static BG jumpy in Safari:
Im not using any snow stacks… but That jump appears to be the background image changing width or height as. the screen scrolls. I have exactly the same issue - its easy to see
i checked that all my stacks windows widths are set the same but it does it on ipad and mac.(Safari) Very frustrating
Would appeciate JW taking a look because if we are all making the same mistake, he should tell us😜
thanks
john a
