I have a site that has No Poage options or styles… I cant edit any of the pages and the content from the top level pages states (null).
It seems to be broken or corrupt??? The Theme is meant to be FULD, but even if I reload that it’s broken… how do I fix this kind of thing??
I’m sure of nothing … But by downloading this theme on themeflood:
https://themeflood.com/blank/
By installing it and applying it on your pages, you may be able to regain control …
Good idea… but alas did not work…
Do you know a way I can take what’s on the web and turn it back into a Rapidweaver file?
Hello, I “believe” that it is not possible …
Fuellemann
(Jan Fuellemann)
March 22, 2019, 11:35am
5
Only if you selected to backup your RW project on the Server (I think in the publishing preferences)
