Foundry columns overlaping on Iphone
When I view my website on iphone 8 and certain laptops the foundry columns overlap my banner text. The view is ok on some ipads or desktops.
Hi there @flmcl – as before, if you want to send me your project file I can take a look.
Thanks Adam, I am not sure how I solved it but is working now.
:+1:
Awesome! Glad you got your layout sorted out.
Just realized what id did different. I originally had a left-floating image inside a container then inside a banner. I eliminated the apparently redundant(in this case) banner and all works fine.
