If I try to register TotalCMS, the register window only appears for less the a second in RW preview mode. I’m not sure but this is maybe a version 1.1.0 problem.
Another user had this issue. I am not sure why its happening just yet. For now, you can simply…
- create a new blank page in your project
- add the Admin Core stack
- Register
- delete the page
What theme are you using?
Thats what I did. A single page Foundation site with only SiteStyles & Admin Core stack on it. If I select preview, I can see the register window for less then a second before it fade out to white…
I also tried other themes but it’s always the same. Also restart RW or Mac does not help.
Great. I can replicate that now. I will get an update out today. Thanks.
I just released an update. It should work now. Thanks!
Thanks that works fine now and thank you so much to reduce my wish list with the v1.1.x update…
