Very odd behaviour going on… opened a project for the first time in a while today, and the first time since updating to RW v. 7.5.1 and macOS 10.13. The project contains a licensed version of Total CMS - the Blog Post page is a sub-page of the Home page. You can see the website here.
When I go to preview either the home page or the blog post page, I get a whole mass of code instead of what I’m expecting - see the attached from the home page - (sorry, necessarily an image as .rtf files not allowed here.)
Yes, all pages in the project are This project has been up and running for quite a while now - not seen this issue when trying to preview before though. I wonder if it’s consequent on Total CMS having been updated?
Hi @joeworkman… OK… I’ve downloaded the TCMS RC3 and republished all files from RW.
Everything is still - and was previously - working on the website BUT the issue I’ve been describing was and still is entirely to do with Preview in RW - that’s where I see all the "gobbledegook’ that I took my screenshot of.
I see, when I scroll down all the nonsense in the RW Preview pane, that there seems to be a video. Could that be the issue - has someone tried to add a video to the blog and that’s perhaps caused / causing the glitch?
I released RC5 last night. I assume that you got that since the downloads for all of the previous betas are gone.
Could you take a screenshot of RapidWeaver for me?
Try to duplicate the page and start removing things from the page until we find the culprit. You dont have anything inside the page inspector tabs that could be causing an issue?
FYI, there’s a release candidate 5 available. And it looks like the final release should be out tomorrow (the link is the comments on the post here: https://weavers.space/content/perma?id=68790)
@jabostick - thanks - yes - it must have been RC5 I downloaded - sorry - I thought I had read it was RC3.
@joeworkman - Screen shots attached - apologies for size. I wonder… have things changed to such an extent in TCMS that I need to completely overhaul the project? For example, the ‘Layout’ and ‘Read More’ stacks seem to have gone?
If this is the case, I need to do a lot of reading to catch up - can you please let me have a link to where I can grab a tutorial or similar?
Did you open the project file I linked you to, @joeworkman, to see if the above is indeed correct?
Your project looks like its setup properly. And it works on my machine just fine. Could you send a screenshot of preview? (that was what I really wanted before, sorry for not clarifying)
Well, that’s good news at least. The 7 screen shots below are what I see in Preview mode as I scroll down. Intriguingly, I note that there’s a Twitter entry (5th and 6th shots) that’s not evident online but removing the HTML stack that is the Twitter feed achieves nothing.
I have tried to have a really thorough look at the cut-down version of the project I sent you and having replaced the only stack showing as “Legacy” (‘Blog List’ on the home page) with the new ‘Blog List’ stack which unfortunately makes no difference to the Preview in RW7.5.1. I have also checked exactly which stacks I have installed for TCMS and have separated them into two groups in RW so as to easily be able to send you screen shots of them (below). I don’t know if any of this will help diagnose the issue but I’ll do anything I can. Your help is very much appreciated.
