I’m having a problem with the TopBar-Stack. I made these settings:
When I change the width of the window, then it does not change automatically to the mobile menu. Between the width 950 px to 640 px the menu is not visible, then it changes to the mobile menu.
I can confirm that when the site logo/title/slogan are visible, the menu does not show up in tablet portrait mode (using RW’s Preview mode settings) when Top Bar is set to default settings. @HGBM, @zeebe
When the site logo/title/slogan are not visible, at least with the menu items I had, there was no issue with the menu displaying properly.
Further, switching the menu from static to fixed displays the menu items - under where the logo/title/slogan appear.
Ah, I see… @HGBM set your “Full Menu at” to Custom, then set the breakpoint to 769 (or the minimum size your menu fully displays) and then you’ll have the triple-bar menu indicator below that breakpoint.
I am seeing the mobile menu at 655, see my screenshot. You can tell my screen is that size as in responsive-resize extension in Safari, I set it to 655.
Are you sure you were at that size, because from 750 to about 962 or so, your site will look like your image, with the full menu and it below the topbar color
Weird, not sure what to tell you, but it is working on your site without issue. I will let Joe know about this, but it almost sounds like a RapidWeaver issue.
Was there ever any resolution to the Top Bar issue. Mine was so unruly I ended up ditching the foundation based site and went with another acceptable theme until I can get some resolution on the Top Bar issues…
I think there are still issues, I made the switch to a non foundation site within the last week. Images don’t work at all, at various points during resizing a page the top bar simply disappears. I was really struggling with it and had to abandon it to get the site done…
