Is there anyone who can tell me how I can publish my Rapidweaver site on the testserver mamp.
When i type localhost I have now a screen what tell me
it works, but I can’t see my site published in the map htdocs
Within MAMP there’s a preferences setting as to where the Document Root is located. This is where you should have published the files to from RapidWeaver. You should probably change the default location:
/Applications/MAMP/htdocs
If you’ve locally published to the correct directory(folder) in RapidWeaver and have MAMP started, then you should be able to view the site by typing in the URL with the port number specified in MAMP’s preferences, default 8888:
http://localhost:8888
You should probably look through the MAMP documentation:
