I have just created a new replacement site copied all the existing publishing setting over and keep having problems with publishing I keep getting this error.
I’m using Vidahost
When I tried to publish my new site it missed out some files so I’ve had to revert back to the old site.
Anything to look out for?
I’m using 7.4.1 and the theme is Royal from Nick Cates
Now I can’t revert back because publishing stops at around 30 files and I get this error
Not sure whether this is connected but the old site had an actual title in the Publishing settings “My Server” but the new site has Untitled Destination?
All sorted I had run out of disk space on my server:slight_smile:
Sometimes, you can try adjusting the ‘concurrent connections’ setting if you get that message as well. Some hosts don’t like the multiple connections
done that a few times - you’re not alone
Thanks guys! It is a little worrying but as soon as you know what it is things don’t seem as bad:-)
