I’m using Nick Cates’ Depth theme. I have too many pages for them all to go at the top of the page, so would like a pull down menu to choose the page to go to.
I can find where to turn off the top menu but not where to turn in a site pull down menu.
Any help would be gratefully received, thank you.
I don’t have Depth but assume it works the same way as other themes. You just create those pages you want to use as drop down menu items in the usual way and then drag them on top of the top level menu item in the Pages panel on the left of RW. Sub-pages appear in the Page list as indented.
See attached,
Clean Menu if you can’t find a built-in solution.
