Can anyone tell me where snippets for RW6 are stored? I did a re-install and there not showing so hoping they’ll be in time machine.
~/Library/Containers/com.realmacsoftware.rapidweaver6/Data/Library/Application Support/RapidWeaver/Snippets
Note the space between ‘Application’ and ‘Support’.
~ = your home directory.
Many thanks Mark that did the trick-found them all in time machine-phew!
You’re welcome, Jspringate.
If you can avoid manually altering too much in that folder, I think it’s for the better. Good luck!
ok many thanks it all helps
A much faster and easier way to find add-ons and snippets in RapidWeaver 6 is to open RapidWeaver and then hold down the Option-Command keys and push 7. Opens the folder right up.
Thanks zeebe, a great and useful shortcut. ;0)
