gavtanner
(Gavin Tanner)
May 7, 2020, 3:24am
1
Using latest version of Rapidcart Pro 4.17.2.
When trying to add a new product or duplicating a product, Rapidcart will not hold any HTML code in the description field even when saving the database.
Any entry here disappears.
Please help
Thank you
Gavin
thang
(David)
May 7, 2020, 3:36am
2
Seems to be similar to this post:
hi -
Using RapidCart Pro 4.17.2 with RapidWeaver 8.6.2 –
when I create a new product in my ‘shop’ all details seem to set and stay as they should except the “Products > Description” in HTML mode. Short description stays correct but long description disappears completely – if I click “Duplicate product” and fill in all the details the long product description may also revert to the original page’s description.
I’ve got around this because I create a .php page for each product and have changed …
@rob
gavtanner
(Gavin Tanner)
May 7, 2020, 3:40am
4
I have this occuring across 2 separate rapidcart projects so i assume has something to do with one of the recent versions installed
gibo
(Gilberto De Faveri)
May 8, 2020, 9:47am
5
@gavtanner as discussed privately, this seems related to latest RapidWeaver 8.6.2 upgrade.
I’d suggest to downgrade to 8.6.1 while we check out what’s wrong.
CC @tpbradley
gavtanner
(Gavin Tanner)
May 8, 2020, 2:01pm
6
thank you.
running on previous version.
trust you will get to the bottom of this issue.
thank you
gav
