Has anyone been successful setting up Rapidsearch Pro on a 123-reg hosted site? I’ve created a MySQL database, which I can log in to via 123-reg’s control panel and I’ve entered the database settings into Rapidsearch Pro’s inspector, as advised by 123-reg’s support, and I’ve published my site. But when I try to access the console at:
http://endtimepuzzle.com/search/files/rspro/index.php/
it tells me it can’t connect to my database.
Looking at the database settings in the inspector, 123-reg told me to use 10.16.16.7 for the Host, and that the database name should be the same as my username. I’ve also tried setting the Host to localhost. I’ve tried setting php to version 5.6 and also to 7, configured in htaccess. I’ve also added a php5.ini file containing
cgi.fix_pathinfo = 1
to the root as described in Rapidsearch Pro’s FAQ.
Anyone got any ideas what I can try next?
