Here’s the latest beta of RapidWeaver 8.1 - Please keep the feedback coming, it’s really helpful.
Make sure you back up any mission-critical projects before using them with this version, and yes, you can run this alongside other versions of RapidWeaver should you wish.
If you find any issues please report them here in this thread.
What’s New in 8.1 Beta 8 (Build 20385b)?
Started work on adding Touch Bar support!
Added support for resizing the preview in the main window
Various other minor fixes
What’s New in 8.1?
Dark Mode for Mojave now supported
Added Amazon S3 as a Publishing Destination
Touch Bar support added
Added support back in for copying a resources URL
Added a new drop down menu to the Simulator toolbar button
Added iPhone XS Max to the simulator window
Add a new preference to disable UI sounds
Multiple selection is now supported in the Resources Browser
Resources can now be dragged from a child folder to the root resources folder
Source list layout is now restored between opens
Files in the Resources Browser can now be renamed
Fixed an issue where the sitemap plugin and sitemap.xml was displayed and exported incorrectly
Fixed an issue with adding edited photos from the resources browser
Fixed an issue with resources not getting exported when previewing
Fixed an issue where RapidWeaver would appear to deadlock while opening projects
Fixed an issue where RapidWeaver would re-publish all files on every publish
Fixed an issue where RapidWeaver would get stuck looping between pages
Fixed an issue where the incorrect path would be used for social tags in the page header
Fixed an issue with multiple buy buttons showing
Removed the javascript that was removing line breaks from the Offroad theme
Fixed an issue where banner images wouldn’t show due to an issue with CSS consolidation
Fixed a naming issue with FontAwesome
Show Properties button in Blog now works correctly
Fixed an issue with page styles being incorrectly applied to Master Styles
Fixed up an issue with the Addons Installer
Fixed up various crashes in the Photo Album Plugin
Fixed a crash when using “Reveal in Finder” and the resource cannot be found
Fixed up crash when using the link panel
Fixed a crash that would sometimes occur in the Snippets Window
Numerous other fixes and enhancements to boring (or too secret to mention yet)
[DEV] Added a method to plugins to mark a page as changed without reloading the preview #2781
The beta has a serious flaw. I’ve tested on 2 different computers. I can republish all with no problem. But if I try to publish pages that have been changed (1, 2 or more) then the app crashes.
I run a MacBook 2017, a MacBook Air 2012 and a MacMini 2013, all now on MacOS 10.14 Mojave, with the first two on SetApp copies a of RW 8.0.3 and the others on Realmac licensed copies. My experience of RW 8.0.3 was the same on all three, a series of increasing crashes when trying to close a file, having successfully uploaded. sometimes it worked, sometimes it didn’t. I found that the only foolproof way was to close RW8 completely and when I next ran it, the file was in a closed state. Recently, it got worse and I couldn’t even do that. Once open, there was no way to close the file at all.
I have been following the various Beta threads and in desperation eventually jumped in and tried Beta 8 on one of the laptops. Guess what? All my file saving issues have disappeared! It works exactly as it should do. Which is not the experience of at least one other user on here. So I guess it shows that software is really complicated and other programs you run may interact in an unexpected way. Personally, I just feel that Mojave itself feels slightly flaky and will be happier when Apple issue a bug fix update.
So, while I await the full release of RW 8.1, so my SetApp versions updates as well, I will happily run the Beta versions, even though there may still be a few things to iron out.
Thanks for reporting this, @JudsonDigital! We’ll take a look.
Just in case, could you email a project to support@realmacsoftware.com with a link to this thread please? Tell them I sent you, and they will get your project over to me to look at
Hi @JudsonDigital. Thanks for sending your project in! Unfortunately I’ve been unable to reproduce the issue here
When RapidWeaver crashes, does it show a Crash Reporter window? Have you submitted that? If so, can you message me privately to tell me the email address you used? I’ll be able to find your crash report and hopefully fix it that way instead
