RapidWeaver 8 won't recognize Stacks 4
I’ve installed RapidWeaver 8 into my new computer. I copied my Stacks 4 from my old computer and installed it but when I open a project I get the following message. The Stacks plugin is missing Try searching for it in our plugin catalog on the RapidWeaver Community website and redownloading it. It has a link but I can’t find where to redownload.
You can download Stacks 4 again from the product page here;
http://yourhead.com/stacks/download
Install it, and then use your serial number to activate it.
Edit; do relaunch RW after installation/reinstall.
That almost worked but because I bought the upgrade, after I entered the serial number from my receipt for Stacks 4, it then asked for the serial number from Stacks 3 and I can’t seem to find that. I must have deleted that receipt from my email.
You can recover your lost serial number by going here;
https://yourhead.zendesk.com/hc/en-us/articles/228020807-I-ve-lost-my-serial-number-
I just saw on the website where I can find my order history!
Thanks so much Rick!!
