Is there a RapidWeaver add-on to build a RTMP video stream portal with a secure login? In other words, to view the streaming RTMP video the audience would have to login with secure passwords. Is there anything like this available?
Hi Howard and welcome to the forums…
I have not seen a plugin or stack that works with RTMP, however, that doesn’t mean it isn’t doable by code injection on your page using HTML and js…
Here are a couple of good resources I found on the web…
Hope that helps
Brad
RTMP media streaming typically requires a server to handle the streaming itself, which is outside the reach of what RapidWeaver can control. If you’ve got the server setup going, a password-protected page with the video embedded for streaming might work well. There’s Lockdown and PageLok (two examples) that might help with this!
—Nik
Thanks for the suggestions.
I am interested in embedding an RTMP player on a RapidWeaver page. Please refer to this site:
http://www.streamingvideoprovider.com/kb/index.php/vt#clip=1234708&time=90.251
There is code that would embed the player on the site. The objective would be to have this player on a RapidWeaver page so that I could stream a live broadcast from the player. I just don't know exactly how I do this in RapidWeaver. Where to put the code.
This particular streaming service looks like a great way to bring secure live broadcasts into one’s site. It's a lot more affordable than other services I've seen.
Many thanks!
Howard Brodsky
