A couple things. The assets you’ve posted for RapidWeaver for Beginners don’t include the 30 and 60 lorem ipsums.
Second thing - In Lesson 2 you show using the inspector on the contact form as a styled text field. When I bold and increase the font of the title it is not reflected in either preview. Also the additional text that I add below the title does not show up at all. Am I missing something simple or is Voyager (perhaps) not recognizing styled text in the inspector?
Whoops, sorry about that. You can get some ipsum text from here http://www.lipsum.com
Make sure you tab out of the text field (click outside of it), and then preview. There’s a small bug in RW where the text will not be updated in preview if the text field has focus.
Not sure what you mean here, can you post a screenshot?
Thanks for the suggestion Robert. I have attached a link to a Quicktime screen capture. Let me know if you see anything I am neglecting. Appreciate it.
From Lesson 4…in my preview the site title doesn’t appear as it does in the video, i.e. About | Ben Counsell. What should I look for so that I can make it appear?
Also (maybe related)…my developer view is showing errors in the code. I have attached a screenshot. I have attached a file.
