RapidWeaver is newly (and constantly) asking for my serial number every time I launch it
Hi All,
The headline says it all - this started happening this past weekend. I’m using RW 7 (which I’ve had for a while) and all of a sudden it’s been asking for my serial. I haven’t added anything to it (or my computer) for a while…
I looked here on the forums and someone else had the problem a while ago - the remedy was to restart but alas that has not worked for me. I’m currently keeping the serial in my clipboard manager :slight_smile: Any suggestions?
Thanks in advance -
Robert
Suggest contacting Dan at RealMac - in case it’s a server malfunction or something which they will be well-placed to help you with. Good luck :slight_smile:
Tagging @dan
You might want to try removing the preferences to see if that helps:
https://help.realmacsoftware.com/rapidweaver-troubleshooting/how-to-uninstall-rapidweaver
I’ve given it a go - thanks for your help!
