Hi all,
What do to next? I can’t seem to find the stack or do I need to buy this?
And which one do I need to buy then?
Thanks!
Hi all,
Thanks!
This looks as though it’s one of Joe’s original responsive layout stacks.
Possibly this one?
Rob
Looks like you might have deleted it from your library. Might check and see if you have a backup of it (TimeMachine maybe) or if you don’t have a copy, I would try to contact Joe’s support page and see if they can help you get another copy. @zeebe?
If he had purchased the stack, it would be on our Order Lookup Page
http://joeworkman.cartloom.com/lookup
More than likely he copied a part of a project file from a demo of Joe’s and did not have that stack, before Stacks 3.5 it would say Template, now it gives a little bit more information.
