RESOLVED: Is there a way to change the vertical distance between images in an Armadillo blog?
Hi!
I would really appreciate if someone could help me with this, as i don’t know anything (almost) about CSS etc.
When I add several images in an Armadillo blog post, there is a vertical distance between the images. I would prefer to have no vertical distance at all. I know that it can be depending on the theme I’m using, but is it possible to change this in the CSS somewhere, preferably in Armadillo?
Here is a link to a blog post with the distance between the images I don’t want to have: Bloggen - Bröllopsfotograf Johan Lindqvist i Småland
The theme is Michael David Design´s Endeavor.
I’m sorry that the web page is in Swedish, but you will see what I mean.
Thanks!
Whenever you ask for help with CSS it’s best to provide a URL to a live page. It’s difficult for people to provide help without that. They have to recreate the environment (Theme, Armadillo, etc) to help.
Thanks. Sounds reasonable.
I have now edited my post and added a link.
You can try this CSS:
.blog-entry-body img {
   padding-bottom: 0;
It works! There is still some small distance but I have also added 2 px white space in the top of those images, so that is easily changed.
Thanks a lot, Doug!
