After the debacle of RW 8.1 resources de-linking. I’m now finding that the right click re-link simply wont work.
For the most part, RW does repair missing resource files issue but in every project there are still resources missing.
So I right-click a missing file. select 'relink resources, locate the file and click ‘Open’. Nothing happens.
Anyone else? Using 8…1.6
Tagging @tpbradley to see if this has been addressed in 8.1.7 beta…
Hey @manofdogz, thanks for reporting this. I’ve done a little testing and I believe this is a thumbnail refresh problem. Can you try doing the relink, then closing and re-opening the resource browser to see if the image is now correct?
Cheers
Thanks Tom - will try this shortly
