Reworked design own card responsive
ok strange behaviour between preview from Elements and publish to local drive
see in the two videoshttps://we.tl/t-n0vvRMW2Mv
It could also be an issue with the HTML you’re generating… but it’s a bit hard to see what’s going on without the seeing actual file.
In one of the videos it looks as though the mobile menu is appearing behind the cards, and this is a layering issue we’re aware of. Are you using our built-in menu component?
Dan
One of my zones was using z-50, all of the zones have a z value to allow layering over each other, changed z to 0, issue goes away,
you mention above you are aware of the layering issue
yes using Elements menu
the issue was the layering everything else is ok, except for the aspect issue I have, mentioned in another topic, this would help the card element a lot if I could adjust the aspect ratio at different screens, I might not quite understand the aspect code and how you implement
I almost always test the main part in tailwind play first to check it works, no Elements controls though
