Rotate title that's upside down
Hi! I have a website using the Nick Cates ‘N Spire’ theme (www.4beauforte.be). Unfortunately, the site title is upside down. Is there a way to rotate it so it is the right way up?
Thank you!
No idea how that has happened and don’t own the theme, but you could try putting this CSS in the global CSS container:
header h1 {
    writing-mode: unset !important;
That selector/value is currently set to ‘tb-rl’ which seems to be causing the issue.
Presumably you have checked the theme options? Is there any other custom CSS which might be responsible?
Thank you! Now the text is rotated 90º and readable, but is there a way to rotate it more so it is facing the website instead of the other way around?
Well yes… its a bit out of whack with the original theme design but I suppose…
Remove the previous CSS snippet and replace with:
header h1 {
    writing-mode: tb-rl;
    transform: rotate(180deg);
    margin-top: 0.25em;
If you run into any render issues with specific webclients take a look here to get more finely grained CSS for whichever client is bugging:
Hope this helps you get the look/effect you really want.
