MaxB
(Max)
30 October 2021 08:08
1
Hey,
since I updated to Monty RW doesn’t publishing my Homepage.
Error: “Couldn’t sign in to your SFTP server”.
FTP / Cyberduck etc. is working -OK!
Checked with Hosting Provider - hosting side is OK.
What can I do? Any idea?
Thanks and regards,
Max
pmjd
(Paul Dennison)
30 October 2021 10:27
2
See this thread, looks like it’s being worked on but no straightforward solutions.
Best to expect your site and transfer it with Cyberduck etc. in the meantime.
My provider updated (06.11.2021) to OpenSSH-Version 8.8 which does not support RSA-SHA1 any more. The login failed. I used to work before that.
So I can not publish my website anymore.
Matthias
Fuellemann
(Jan Fuellemann)
30 October 2021 10:32
3
Can you make a new publishing setting and enter all data by hand then try again?
MaxB
(Max)
30 October 2021 12:53
4
Thanks, I tried, NOT working…
MaxB
(Max)
30 October 2021 12:58
5
Good info. I Hope RW will find a solution soon
system
(system)
Closed
29 November 2021 22:59
6
