RW8.1 crashing while saving
The latest build (20560b) is crashing when I try to save a project. Anyone similar problems?
Been using 20560b since it first came out, worked on and updated 4 different client sites and had no problems since update.
Not seeing it either. Works fine other than SFTP.
Does it happen on on all projects?
You really should reply to the beta release thread rather than a new thread. Otherwise any issues you’re having might go unnoticed.
I’ll reply to the beta release thread. I’ve gone back to Version 8.1 (20541b) and the problem isn’t happening. Thanks for your reply.
