I want to sandbox my current “rwproject” using MAMP. I have setup permissions in system preferences etc. correctly and started MAMP prior to publishing to
/Applications/MAMP/htdocs/rwproject
Then testet connections in RW-bookmark manager successfully (“Connections test successful”). But when I try to publish the project, I receive an error:
“Could’t upload to your FTP server: Access denied to remote resource”
The credentials are setup correctly, what am I doing wrong?
I haven’t actually tried publishing a site to MAMP but I have exported sites for viewing in MAMP and then had problems getting Armadillo to set up correctly. I found that the permissions kept getting changed (don’t know why). I found that the quickest way to fix them was in my FTP program (Transmit). I hope you find this helps.
When using export I had no problems, however, I want to use “publish” because I when making changes it should only publish the changes to my local sandbox.
hi there @sushlinger, the best way to work with MAMP is to head over to joe workan and watch the very extensive video he did on MAMP. it tells you everything you need to know. i use it on almost every site i am creating. i export my project to my desktop and than call it up with MAMP. works beautifully. but go and check out joe’s video, it gives you all the beef.
greetings, tomas
sushlinger
