I’ve ben experimenting with the suite of Sentry CMS stacks and wanted to find a way of placing the login icon neatly in the footer, aligned with the other content there. The stacks’ author Will Woodgate has come up with a way of achieving this and I thought it was worth sharing in case any other Sentry users would like to do the same thing. All the clever stuff is his, any mistakes are mine.
Note: because different themes use ExtraContent areas in different ways and place them in different parts of the page, you’ll need to experiment when assigning the EC stack a number. It’s just trial and error I’m afraid.
In Edit mode, go to Settings in the left hand column and choose General
Place the following code into the Footer field
<div id="extraContainerxyz"></div>
where ‘xyz’ is the number of the ExtraContent container you want to create -
Drop the free ExtraContent stack into the page where you want to use the Sentry Login stack
Drop the Sentry Login stack into the ExtraContent stack
In the Page Inspector, assign the ExtraContent stack the same number as you’ve used in the code that’s placed in the footer in Step 2.
Switch to the Code page in Settings and select the CSS tab
Add the following code to your site-wide CSS, noting that first that the number next to the ExtraContent container must match the number used in Steps 2 and 5; and that you may have to fiddle with the bottom margin to line the icon up correctly.
#extraContainer5 {
display: inline-block;
}#extraContainer5 .sentryLoginTrigger {
margin-bottom: -6px;
Save and preview.
You now have a login icon that sits neatly in the footer.
Rob
