SimpleSearch and RapidSearch Helper on Foundry
Hello there, I’m having a little trouble integrating RapidSearchHelper with SimpleSearch on Foundry. Whenever I set the RSH integration to ‘SimpleSearch’ it swaps back to ‘RapidSearch’ every time I close RW. I publish the files and I type in a word and it goes to the designated search page on my site, but with no results shown. Is anyone else having trouble with this?
You could if you want, but Adam answers questions on this forum as well(One thing no one wants is double posting questions on different forums). But since your integrating a stacks4stacks product with rapidsearch, it’s probably not Foundry causing the issue.
I have RapidSearchHelper and use it with RapidSearchPro and it works fine.
Just did a quick test and there appears to be a possible bug. I don’t have simple search, but I just tried changing both in a Foundry project and a non-foundry project. If I change to SimpleSearch it does change back to rapidsearch after closing RapidWeaver. Will woodgate @willwood does both products, so I just tagged him, but you may wish to hit him up with support at stacks4stacks.
So no not a Foundry issue.
Thanks for the tip = will do
This is really helpful and thank you. Noted on double posting and appreciate you highlighting that. Hopefully Will has some answers to this
You can try his contact page
https://stacks4stacks.com/contact/
Many thanks for this
As I said I don’t have simple search, so I didn’t do a complete test. So it could be something missing on that side. I know it doesn’t switch back with RapidSearch Pro(I have that) and the switching appears to not be Foundry (or any theme) related.
