Site doesn't load at top
Hello
I have build my first - one page- foundation site.
The problem is that it will not load at the top of the page.
Thanks for ideas to solve this
http://vii-sual.nl
In your foundation form, you need to disable the ‘autofocus’ selection on the “voornaam” field of your form. It is asking the page to jump down to that section of the form, where the cursor is blinking and ready for input.
Uncheck autofocus, and it should load at the top as expected
Thanks Jason, that works
