Top bar issues foundation stock
I was working in a new website and i notice that the foundation top bar stock was the wrong high size ant the titles in the wrong position i tried to fixed through the top bar menu area inspector, didn’t work any idea how to fix this problem?
My guess is that you recently updated the Foundation stacks but did not update the Foundation theme
http://foundation.joeworkman.net/theme
RapidWeaver does not update themes automatically, if you want automatic updates for themes, we suggest you get the Waterfall plugin by Nimblehost - http://nimblehost.com/store/waterfall/
Foundation works great with this and if you add the Waterfall plugin to your project file, it will check for updates for you.
Let me know if this helps
Thank you so much, it works now.
Glad to hear it is working for you now!!
