I know you can buy themes but are there any places to get different type of site backgrounds?
Also, is it hard to make custom backgrounds?
Check out
Background patterns
http://thepatternlibrary.com/
Linear CSS gradients
http://colinkeany.com/blend/?ref=webdesignernews.com
More Gradients
A few more…
Excellent! THANKS guys!
I tried tp use a SVG image as a background but the theme wouldn’t let me. Would that be an issue with the theme, or does it have something to do with using a SVG as a background?
I use the css inside of @joeworkman’s wallpaper.
That stack allows you to create your own background, doesn’t it?
I was thinking of using the site name, tiled, at an angle…
just the ability to add css
tiling can be done other places.
