I suddenly started getting this message - I am not aware I have used any snippets. What is this all about?
FA5 Pro Warning
We found legacy FA4 snippets on your page
You have two options…
- If you added the FA4 snippets yourself onto the page, you can go through all of the snippets and update them to be the new FA5 snippets.
- If you do not have control over the snippets, you can easily enable the FA4 Snippet Upgrade option inside of the FA5 feature swatch.
