I really like the way the two white boxes overlay the above banner/header image. I can make something similar but when I resize the screen, the white background product placement boxes move around rather than stay positioned. I hope this make sense (yikes).
I use Joe’s Foundation, haven’t upgraded to 6 as yet.
how do you expect the layout to behave on smartphones? If you’re trying to preserve the two panels side-by-side, they’re going to be too small to read comfortably IMHO. I’d expect them to stack in some way. Or maybe think about hiding the panels below a certain breakpoint and replacing them a different way of presenting the information on small screens?
Fantastic, thank you, Rob; I really appreciate you replying.
I want to set it up so that the two panels adjust for tablets and smartphones. I just grabbed another screenshot from my iPhone, so two columns for PCs and tablets in landscape, and single columns for tablets in portrait and smartphones while maintaining that little bleed over the header image.
I’m usually pretty good at overcoming some areas with trial and error, but this one has me stumped.
I’ve not built a site in Foundation for a while but as I recall, the trick with things like this is to design the mobile view first and then adjust the columns so they ‘split’ into two when you reach the tablet breakpoint - rather than designing the two column layout and trying to make that stack at mobile.
Thanks, Rob. I can get a 2 column stack (currently using Grid) to move to single column for smartphones but I can’t work out how to get the top of stack in any screen mode to bleed over the header image above just that little bit as per the images shared. I really like the white box with round corners bleeding over the above image a little.
Wow Rob, that looks like it could be perfect. I just checked out the overlay video. I’m looking forward to exploring this further and sending BWD some shekels. Thank you so much
