I guess only someone with this Theme will be able to help, the css i have created for the “.nav-backdrop” does what i want perfectly, which gives a slightly opaque effect.
whereas above, if i apply the same css to the “.banner_overlay” it does nothing, i can only get a plain colour, i cannot get anything opaque to be displayed. I would really like the Banner Overlay to be Opaque as well if at all possible ?
Furthermore, something else has now cropped up, if i try to Publish this project using RW7, i get this error message
and i havent knowingly “specified to use a banner” ???
Tim,
I don’t have that theme and not at my MAC right now but a URL would help.
From the screen print above you have two colors being applied to two classes. One is a color name blue the other is a full rgba value with a transparent setting of .5. The .banner-overlay is set to a solid.
Hi @teefers thanks for having a look at my question, i have now applied a Banner via General settings, i can now happily apply an opacity setting to the banner background which is now more or less what i was trying to achieve. http://timmytoad.org/test1/ there is a URL showing you my progress so far
and this is the CSS now in place in Settings/Code :-
.nav-backdrop {
background-color:rgba(51, 51, 51, 0.6) !important;
.banner_overlay {
background-color:rgba(51, 51, 51, 0.6)!important;
