Can someone point me to the video tutorials in the Elixir theme, like the ones that are mentioned on the Elixir video on Voyager Pro theme?
https://elixirgraphics.com/themes/voyager-pro and then click on the Tutorials tab. I think that is what you’re looking for.
Thanks. Do you know if the pro version supports the new banners feature in RW7?
Yep, it does: "Voyager Pro supports RapidWeaver’s new Banner setting right out of the box. Drag-and-drop your banner image into the image well in the Site Setup or the Page Inspector and you’re ready to go! "
See here: https://elixirgraphics.com/previews/voyager-pro/options/ at “Customizable Banners”.
Is there a way to Have a full image in the background?
Is it possible to use alpha channels/transparent foregrounds with the headers and/or extra content?
Changing the site background is not an option of the theme. You can use a PNG, with a transparent background, in the banner area. It should accept, JPG, PNG and GIF images.
All of the themes options are outlined on the page linked above by @RapidBase.
Thanks much. Do you have a theme where that is an option?
