Some things to correct
Hi, here’s some problems to correct :
  • in Menu, Global override “Desktop drop zone” text appears with the “D” half hidden by lateral bar
  • local publishing don’t work
  • Menu links in Menu don’t work.
Hmm, I couldn’t find this, can you post a screenshot?
Perfect, that ison the list to fix :+1:
That seems to be working here, what exact issue did you run into?
Did you pick a destination in the local setup? (see below)
In the meantime you could try and use the “Export Site” from the File menu.
Here is the “D” problem.
Here is my publishing setup.
It doesn’t work, as the export site doesn’t work. I use Mampro up to date but it can nothing Elements doesn’t publish files in the directory (or export).
I’m with Mac M2 Ultra, Sonoma 14.5.
Perfect, we’ll hopefully get both of these fixed in the next beta!
I tried publishing locally as well and ended up with a notification:
Elements
Unable to export’.
The resulting log displays the following item:
Publish Site
Export failed
With the contents:
Invalid Page Template
The page template of the current theme is empty.
0 CoreFoundation 0x00000001857232ec __exceptionPreprocess + 176
1 libobjc.A.dylib 0x000000018520a788 objc_exception_throw + 60
2 Elements 0x0000000104b63e9c Elements + 3751580
3 Elements 0x0000000104b65c4c Elements + 3759180
4 Elements 0x0000000104b67b40 Elements + 3767104
5 Foundation 0x00000001867c3b8c NSBLOCKOPERATION_IS_CALLING_OUT_TO_A_BLOCK + 24
6 Foundation 0x00000001867c3a4c -[NSBlockOperation main] + 104
7 Foundation 0x00000001867c39dc NSOPERATION_IS_INVOKING_MAIN + 16
8 Foundation 0x00000001867c2d84 -[NSOperation start] + 648
9 Foundation 0x00000001867c2af4 NSOPERATIONQUEUE_IS_STARTING_AN_OPERATION + 16
10 Foundation 0x00000001867c29e4 __NSOQSchedule_f + 172
11 libdispatch.dylib 0x000000018542d470 _dispatch_block_async_invoke2 + 148
12 libdispatch.dylib 0x000000018541e3e8 _dispatch_client_callout + 20
13 libdispatch.dylib 0x00000001854218ec _dispatch_continuation_pop + 600
14 libdispatch.dylib 0x0000000185420f08 _dispatch_async_redirect_invoke + 584
15 libdispatch.dylib 0x000000018542fea8 _dispatch_root_queue_drain + 392
16 libdispatch.dylib 0x00000001854306b8 _dispatch_worker_thread2 + 156
17 libsystem_pthread.dylib 0x00000001855cafd0 _pthread_wqthread + 228
18 libsystem_pthread.dylib 0x00000001855c9d28 start_wqthread + 8
This happens regardless if I set the directory to one being synced with iCloud (/Users/bryanrieger/Desktop) or one that isn’t (/Users/bryanrieger/Sites).
Don’t panic, we know what this issue is and it’s already been fixed — Will be working in Today’s beta :wink:
Now I’m jealous, for me it just closes the window and then nothing. You’re lucky to have real crashes. :crazy_face:
