Split theme missing in RW8
When I tried to open my project in RW8 it says that the split copy theme I am using is missing. How can that happen when I haven’t changed anything? How can I fix this?
Hi @simonthetutor,
Can you see the Split theme in your Settings?
Make sure the Split theme is listed in the Themes tab, and that it’s checked as in the above screenshot so that it shows up in RapidWeaver.
Thanks so much for your reply.
The split theme I had used was a split copy I realized and that was missing. I opened the project, found the split theme and used the master tab and my already published website to change the split theme back to the way things look on my website. So I think I am good.
Really appreciate you reaching out though. Thank you.
Simon
