Dear gurus! Firstly, forgive my English.
I just can not configure the Embed stack. I’m trying to create a website with lots of pictures (these are illustrations of children’s books that I was preparing for printing) and they are quite large. Here is the sequence of my actions.
In the RW project (3.5.2), I create a new Stacks page.
In the specified field, I put the Embed stack.
In the Transmit program, I create the Assets folder and load several files into it.
I set permissions on the folder - 755, on files - 644.
Not sure where you’re getting that path name. Looking at your file directory it appears that you have a www directory inside the main directory, and the assets folder is inside that.
The file path you’ve given shouldn’t have to sets of double slashes //. Try dropping all the XXX.XX.XXX stuff and start with the second set of double slashes.
the “www” is your main web root directory… you would point beginning with /assets/ being your first folder. Assuming your stack is asking for a URL the path would be http://portfolio.scansione.ru/assets/
Whatever Transmit gives you will be wrong. This needs to be a relative path, not an absolute path. A relative path never starts https://, http:// or ftp://.
Wow! It worked!
True, every image has a signature:
Strict Standards: Only variables should be passed by reference in /home/u172786/test.scansione.ru/index.php on line 102
Thank you! I’ll cut further
Once again, accept my sincere thanks. You are best!
